Beeping & Stop light coming on
jodie164
Post by jodie164 »
Hi, I have a 03 plate 206 diesel and when I'm driving along either the exclamation mark light comes on with beeping or that plus the STOP light comes on. It was happening mainly when I was doing a right turn but it is also happening when I'm driving straight now(but normally at the bottom of a hill) too.
I've checked the oil & water levels and have recently had my rear brakes and cylinders replaced.
Can anyone help as its driving me nuts :love-thx:
Re: Beeping & Stop light coming on
You need to get fault codes read as it could be one of many things. Tell us what codes you have and we will try and help
Have you checked your hydraulic fluid level? You say you've recently had work done on your brakes. Maybe the hydraulic fluid needs topping up - if so you could have a leak at one of the unions. Or maybe it wasn't topped up fully when the work was done.
Well spotted Ron. I missed that!
jodie164
Post by jodie164 »
Thanks, I'll get the fluid levels checked and see if this helps first.
