Roof not working no big bong noise
Monkeyshlut
Post by Monkeyshlut »
Hello, sorry if this has been asked before but I've searched all over for an answer and not found one.
Got a 2001 1.6 206cc the roof worked fine last year but since its been nice this week I've tried to open it and now it doesn't work. When you unlock the catches there is no bing bong noise?
What things can I check for my self without taking to a garage?
Are there any fuses for the roof and if there are where are they located.
molly
Re: Roof not working no big bong noise
Post by molly »
Hi.
The reason no big bong is one of your micro switches is not working on the roof locks.
When you unlock both sides the micro switches sends a signal to the ecu.
If you try to operate roof switch when roof is not unlocked it will beep at you quickly,.
So check out roof micro switches.
Andrew.
