Hi' I'm wondering if anyon can help me? I have a failed gearbox input shaft bearing on a 1.4 ltr 206 with what I believe is an MA gearbox. My question is relatively simple and is this, "can I remove the bell housing from the gearbox (as thats where I beleive the bearing outer is housed), or do I have to strip the gearbox down from the other end and remove the shafts and selector(s) any help would be much appreciated.
Gearbox input shaft bearing
ptomo
Re: Gearbox input shaft bearing
If its the input shaft I'd of thought box off all gears an shafts out and pull bearing out of the case,I've done a few pg1's on rovers an that's the only way
See here if you want to have a go gearbox rebuild
