When I change gear mainly from first to second gear and release the clutch pedal I hear a knock.
Do you all think the clutch could be on it's way out or do you think I would get away with cleaning the clutch up?
Also is there a "how to" guide on clutch removal?
I have a 02 plate, 206cc, 2.0L with only 56k on the clock, only driven by my wife and not very often.
Any help would be appreciated.
Clutch knock
Re: Clutch knock
More likely an engine / gearbox mount, or bush / joint gone on front suspension.
Can't really clean a clutch and it would serve no purpose.
