I have manually closed roof.
Makes continually beeping now and doesnt work.
The clips at back can be turned 90% apparently but how?
Any owners in south London with same previous problem ?
Any help please
roof reset
PEUG1
Re: roof reset
Found the solution very easy!!!!
Anyone with same problem please post
Re: roof reset
Hi Peug1. Glad you found an answer to your problem. Would you care to share it?
PEUG1
Re: roof reset
With boot lid up/open,the switch in boot to the left where "roller blind" hooks/sits onto. I placed a small metal object between "blind" and silver metal thats exposed to depress the switch contact.
Pulled out both plastic clips from "notches" and rotated clockwise( not into another notch).
Job done.Metal object removed after opening and closing normally. Works perfectly.
Oh problem began when I interrupted opening sequence and attempted to close.
Hope this helps some others.
