Greetings from a new member
alec586
Hi to everybody. I've just bought the missus a 2003 206cc with the 2ltr engine. Have got issues with the roof, where it bongs when I unclip the roof, windows go down then I hear the pump working but nothing happens. Also the cooling fan does not work. So I've got my work cut out for me.
Re: Greetings from a new member
Try nipping up the pressure relief valve in the boot (the valve you relase to manually operate roof)
Cooling fan only operates at full temp or with aircon. Have you checked the fuses?
