Cannot buy correct part
Hobittual
Post by Hobittual »
1999 1.4 lx petrol 206.
I cannot find a ISV, IAC, Idle control valve or whatever you want to call it, with the serial B31/00 Magnetti Marelli.
I can get a lot of others, but I have had to return them all.
All the normal idling and cutting out probs have been going on for over two months now. I had a fault scan done and it found, as written by the mechanic:
64 Temp coolant sensor circuit
165 Idle speed valve circuit
So my first attempt has been to change the Idle speed valve, as I say I can't get the right one. Could the coolant sensor be causing me problems?
Totally desperate.
Hob
