Opening hooks and wont boing
sjerby
Post by sjerby »
Hi mates, I'm driving a 2002 plate auto 1.6 cc,
suddnely I have a problem with the roof, when opening the hooks there is no boing that says "ok now u can open the roof"
as im trying to press the open button it wont do anything because it didn't recieve info about the hooks open.
after opening and closing the hooks for many times it works for a time or two but then again the hook open recognition fails, which part of the hooks is responsible for this problem? is there any sensor around the hooks?
thanks
Re: Opening hooks and wont boing
There are two microswitches in the screen surrond where the latches are. Might be sticking.
Try a search or two because this is fairly common.
Hi and welcome.
There are 2 microswitches, 1 on each windscreen pillar. A search of this forum will throw up loads of info
sjerby
Post by sjerby »
Thank you guys, will do !
rollsroyce2014
Post by rollsroyce2014 »
hi i have recently bought 206cc the roof wont open,when i start to drive the car there is an audible sound after about 5 mph,which is constant.When i try to open the roof the same sound occurs but no movement of roof help;;;;
