hi,
I've got a 2002 Peugeot206, both my dipped beam head lights went off. I've checked the fuse box but they look fine. could you please help me with it?
the full beam lights are working, i appreciate if you can let me know what could be the possible problem.
Best Regards,
Amir
both my dipped beam went off
Re: both my dipped beam went off
Did both the lamps stop working simultaneously? What were the circumstances? Any other symptoms? Have you tried replacing either or both of the dipped beam bulbs?
You don't tell us much about the model of your car. Which 206 is it? Specific model and a bit of history would help us.
If fuses 9&10 are OK, check the bulbs and let us know what you find.
