Clutch Replacement
tharetard
Clutch Replacement
Post by tharetard »
Hi Guys
Clutch is very high on this car, so have it booked in to get changed with a friend (only £100)...
I need to buy the parts though... Do I need to buy one specific for a 206cc? Or will a normal 206 clutch work?
The car is a 52 plate.
I have found this part on ebay:
http://www.ebay.co.uk/itm/New-Peugeot-2 ... 1124303381
Is this everything I need for a clutch change? Do I need a cable too? The car has done 96000 miles without clutch change...
Cheers in advance
Peugeot 206cc
2002 (52 plate)
1.6l petrol
It says Quicksilver on the side of the door, but I have my doubts...
Re: Clutch Replacement
Hmm. No manufacturers name. I would buy a known brand such as Valeo (oe)
After all, you don't want to be doing it all again due to clutch judder, or release bearing failure.
The cable (if fitted) can always be changed later if need be.
Buy cheap- Buy twice!
tharetard
Post by tharetard »
Thank you for responding!
Will a clutch for a 1.6l 206 fit the 206cc?
Peugeot 206cc
2002 (52 plate)
1.6l petrol
tharetard
Post by tharetard »
Any benefit in fitting a stage 3 clutch? What difference would it make?
http://www.ebay.co.uk/itm/TORQUE-FAST-R ... 2a23802c01
Peugeot 206cc
2002 (52 plate)
1.6l petrol
Probably horrible to drive on roads. Too snatchy. Might be ok for track where revs are always high. Bet it wouldn't last long either.
Stick with standard ... and yes, hatchback and cc clutches are exactly the same.
tharetard
Post by tharetard »
Thank you :)
Peugeot 206cc
2002 (52 plate)
1.6l petrol
Peugeot and Citroen 1.6i are same too ...
I'd go for a Valeo clutch. They seems to be in favour at the moment.
Don't forget, fleabay isn't always cheapest .. and cheapest can be a recipe for buying twice and fitting twice ... try a proper motor factors (Not sure where you are but companies like Sutton Auto factor aka buypartsby.co.uk, Unipart, Allparts Automotive, etc should be ok)
