Thanks in advance
Can't close my roof
jo williams
Can't close my roof
Hi everyone, I was putting the roof down on my car and without thinking switched the ignition on. The roof stopped half way through and wouldn't go back down or up for a while. It went down in the end but did the continuous bleep all the way home and now I cannot get it up again. Does anyone have any ideas?
Thanks in advance
Thanks in advance
Karrot
Re: Can't close my roof
You say it went down eventually, did it complete this under power, or did you manually complete it yourself??
K
K
Enright
Hang on - you say you switched the ignition ON?
The ignition should be on all the time when operating the roof, or you're killing your battery.
You've probably confused it a bit but it's do-able. Can you put your location in your profile please?
There may be someone close enough to help.
BCingU,
Neil.
Neil.
JustJ
I turned ignition off by mistake - so I think I have the same problem.
The roof continued to collapse itself but now no response (apart from beeping) when trying to use electric roof
Karrot
Check this post out
http://www.peugeot206cc.co.uk/viewtopic ... 73#p120111
Might solve your problem.
K
K
