roof
henny
roof
Post by henny »
can any body help
i cannot get my roof to work checked the sensors they seam fine anybody got any sugestions.
thankyou
Re: roof
Henny a bit more detail of what is, or is not happening would help. Also there is a dedicated roof section. have you looked there for suggestions?
henny
Re: roof
Post by henny »
do you know any body breaking a 52 plate 206cc it seems one of the sensors on the parcel shelf assembly is not clicking and they come as a block near the parcel shelf piston i am in salisbury if any kind person can help me.
thanks henny.
henny
Re: roof
Post by henny »
replaced micro switch on assembly. pump has stopped working can you advise i know they have a time out can you tell me how to resett the system.thankyou henny
Re: roof
You really need to give more info other than "pump has stopped working". Are you getting catch release chimes windows down etc: What exactly is happening?
henny
Re: roof
Post by henny »
just constant beeping windows do not go down when the roof catches are undone nothing seems to happen
thanks steve
Re: roof
Constant beeping? When driving? When operating switch? When undoing catches? When?
henny
Re: roof
Post by henny »
hi do you know any body that has got the three micro switches on the loom mine is faulty.
i need urgently thanks
henny
henny
Re: roof
Post by henny »
hi got the roof to work once replaced the parcel shelf micr switches and replaced the pump cannot find a way to bleed the pump or to fill pump with oil.
when putting the roof up and down manually the pump is forcing the oil back up through the refill hole with loads of air ,nearly there any suggestions i am thankfall for your help coll here is my mobile no 07788 712485
i need to fix this an you call me please. i will phone you straight back .
thankyou for your time.
henny
Re: roof
Post by henny »
can any body help.
Phaeton
Re: roof
Post by Phaeton »
From what I have read Henny somebody is trying to help you, but you are not helping them to help you, they keep asking you questions which you keep ignoring & not answering.
Alan..
henny
Re: roof
Post by henny »
roof fixed thanks for help
Re: roof
As usual, no information on what was wrong, so we are all left in the dark and no help to anyone else.
Glad you got it sorted though.
Phaeton
Re: roof
Post by Phaeton »
Well I have just found a roof fault so lets add some information & see if anyone has a result. Roof goes down fine without issues, but on coming back up the roof closes as it should but the drivers rear quarter only comes up so far & then sticks, the rest of the windows close as they should. Help, I was going to give the car to my sister but with the ABS fault & now a window fault I don't think I will.
Alan..
henny
Re: roof
Post by henny »
sorry i was a bit out of sorts trying to fix my problem
here is how it goes.
the pump was seized.
the micro switches on parcel shelf were not working.
i resolved this by replacing the pump inc relays.
replaced the parcel shelf mechanism with one from a 56 plate mine is a 52 plate.
upgraded the micro switches from a later model.
had air in system found a way to bleed.
all works ok. but still air in system has boot is very slow going up and down.
hopefully should bleed it self in normal operation.
your quarter window needs lube mine was the same i sprayed mine with lube that contains p.t,f,e, .
spray down into mechanism and work windows up and down hopefully should fix.
thank you to one and all who tried to help me sorry i was vague/sometimes you just have to teach your self. and two weeks later it works.
cheers henny....
