parcel shelf toggle missing and cant operate roof manually
bigtez492
Post by bigtez492 »
:mad:
PLEASE help. my roof on my 2003 206cc 2.0 will not raise. i look to raise it maually but there is no toggle to release the parcel shelf. Is there away to lower the shelf and raise the roof. very frustrated. Thnk in in advance
Re: parcel shelf toggle missing and cant operate roof manual
Yes if you search at the top of the roof forum for the roof video, it shows what the toggle does so you will be able to see how to release the ram without the string.
joesulli789
Post by joesulli789 »
Capncol wrote:Yes if you search at the top of the roof forum for the roof video, it shows what the toggle does so you will be able to see how to release the ram without the string.
I have a 2004 model and it says to insert the allen key in the hole next to the toggle but I cant see where it goes in to ,very confusing ,I want to lower the parcel shelf manually,can anyone help thanks
If you look in the hole in the plastic cover, where the toggle used to emerge (before they deleted it), you will see a silver metal part with a groove in the face. I believe you push that part inwards, say with a screwdriver.
joesulli789
thanks ,will give it a go,the instructions in the manual are not very clear on what part to insert the long allen key in to thanks.
