what type of oxygen sensors do pug 206cc s16 have
bertie1
Post by bertie1 »
are they zirconia or Titania Oxygen Sensors)? cheers
my fleet::: 2x peugeot 206cc 2.0 si6 mercedes sl aston martin db9 volante 1937 ford model y hotrod range rover
Re: what type of oxygen sensors do pug 206cc s16 have
Just buy bog-standard Bosch ones. OEM parts rarely last .. or in the case on NGK, their lambda sensors are the wrong ohm rating! (As are probably most generic parts).
If you want to save a few quid, but Bosch Universal sensors and splice them into the existing wiring (no soldering!). In 99% of cases the sensor is the same, but the wiring makes it operate differently due to the length, etc. Look at the two on the 206CC: one has a longer cable than the other and plugs are different colours so they don't get mixed up.
Saved about £40 when I had to replace my Alfa lambda by fitting a LS615 Universal :thumbs:
If you really need to know, try the Bosch website ...
bertie1
Post by bertie1 »
no im not buying any been offered some testing equipment one of them being an oxygen sensor testing kit but the kit only does one type of sensor the zirconia ones
