help needed to reset eylos
Tony_termite
Hi all ive recently joined as i have just bought my first 2006 206cc 1.6hdi with 85k on the clock within a few days had the clean diesel filter alarm so i have removed the dpf pressure washed and topped up the eylos tank i had no faults for low tank level but it was empty how do i go about tesetting the eylos so it will does again or will it still dose ok ive downloaded diagbox with the updates its installed i tried to connect with my vagcom lead i use to code my BMW but its not talking to my car do i need special leads if so can somone point me in the right direction or if your local to Bromborough wirral would be willing to do it for me?
leegsi
Re: help needed to reset eylos
You will need the PP2000 lead too
Tony_termite
Hi what does the pp2000 lead do? Can i make one?
You will need a Lexia-3 cable set ...
leegsi
Something like this: http://www.ebay.co.uk/itm/PP2000-Lexia- ... 487b0b86c8
