I've just bought my first 206cc and the above warning light is on constantly. Is this a serious fault?
Many thanks
ESP/ASR Warning light
- bertie1
Re: ESP/ASR Warning light
hi welcome may be worth viewing http://www.peugeot206cc.co.uk/viewtopic ... 23&t=11358
my fleet::: 2x peugeot 206cc 2.0 si6 mercedes sl aston martin db9 volante 1937 ford model y hotrod range rover
Could be many things. Get the fault codes read rather than guess.
iooiuk
Well it's a MOT failure.Mrs B wrote:Hi,
Many thanks
Wendim
I have just purchased my 206cc and within a day the abs and esp light are illuminated, when I took a look under the car I could see a cable hanging free which I have now worked out is the rear right sensor so I have bolted it back in place, a friend came to clear the code and within moments of him leaving the lights were back??? any suggestions, I was hoping me putting the sensor back would rectify the issue :-(
Wendy
Wendy
206cc newbie
2005
1.6HDI
2005
1.6HDI
As above. Fault codes needed.
Wendim
It did say on the diagnostic reader 'rear right abs sensor' so I am guessing a new one is needed
Cheers
Wendy
Cheers
Wendy
206cc newbie
2005
1.6HDI
2005
1.6HDI
leegsi
Or broken wiring or damaged reluctor ring.
Wendim
When the light first appeared I looked under the rear end to see the sensor hanging loose boltless so hoping a replacement will do the trick, does anyone. Know what size bolt holds the rear sensor
206cc newbie
2005
1.6HDI
2005
1.6HDI
Part No 6922 87, Description - Screw with Base DIAM 6X100-22Wendim wrote:.. Know what size bolt holds the rear sensor
Wendim
Anyone know the part no. for a rear abs sensor, ordered from Ebay and it doesnt fit :-(
206cc newbie
2005
1.6HDI
2005
1.6HDI
Get one from a local motorfactor. They will match it using your reg No:
