Ignition auxiliary position no longer has power
The.wine.doctor
I have a 206 cc 2001, 138HP. VIN VF32DRFNF41737908 if it helps! All was working well until a CD got jammed in the player. I had to remove the unit's fascia to pull the CD out. Since then there has been no power to anything with the key in the auxiliary position. All cables at the back of the unit are apparently undisturbed. When the engine is running everything works. I cannot find a blown fuse. Any suggestions how to fix the problem or how to troubleshoot it?
