Anyone got the factory AL4 download link, please?
Need the pics /manual to replace the solenoid valves.
Peugeot 206 AL4 workshop manual download?
Dusty
Re: Peugeot 206 AL4 workshop manual download?
Anyone got a parts diagram of the manual valve and operating lever assembly and any adjustment tips Ta
Luditus
This video might help. https://www.youtube.com/watch?v=WsJBWWLtP7w
gpktm
Hi guys
I need also to replace the solenoids very soon. I would like to ask. Do you know if the ECU needs resetting or reprogramming after the valves replacement?
As I understand it, if the solenoids are the original 50Hz type, and are replaced by the Borg-Warner 100Hz type, the AL4 ECU should be reprogrammed to support the higher frequency. I believe this is done by the car being connected online to Peugeot servers, so only dealers and recognised AT repairers can do it.
Note that later (not sure from when) cars had the 100Hz type fitted on build.
