Sorry to be coming straight on the forum with an issue I would not normally do the but its kinda important
Im about to buy a 2005 206 convertible hence this post here in the roof section right the car checks out fine everything seems to be a1 but on checking out the roof operationI had to open the windows manually then the roof opened and closed fine I've come home checked out some videos on youtube and most if not all open the windows for you when you've open the 2 roof locks and then operate the roof switch
is this normal or should i be thinking theres and issue if its just a simple reset or minor fault I don't mind sorting it myself but not really knowing these cars at all I thought it best to ask an expert
anyways thanks in-advance regards Terry aka dockrat
