key dont work
orac
key dont work
Post by orac »
hi all im a newbee, anyway , key wont work , no led when button is pressed,had battery checked and ok.The key will only open each door, not all at once as it should, i'v not had time to check any fuses yet, any idears as to whats up would help . and the car is a rolland garos 1.4i auto.
Re: key dont work
When was the fob battery last renewed? If it has a brand new battery in it and now doesn't work, or if the old battery was taken out to test it and then put back in, I'd try reprogramming it as per the instructions in your Owner's Handbook. If the battery loses it's charge or is taken out for more than just a few seconds it can lose its memory. The instructions in the handbook are simple to follow and won't take more than a minute to do.
orac
Re: key dont work
Post by orac »
here again ,i had the key checked out and it doesn't seem to be sending a signal?, which is why the red led dont work. so sort that and fingers crossed it maybe ok .
Re: key dont work
No led means no power in the key .. that could be the battery or the microswitch is broken.
orac
Re: key dont work
Post by orac »
hi all, i have been having a look at the fuse box, from what i can see all is ok, i have no central locking at all, not even when i sit in the car ,all doors closed, bush down the button and only my door will lock. so where t start looking for the problem ?. i just want to be able to lock all the doors/boot with the key in drivers door, that will be good enouigh, nice to have it all working. anyone with some ideas ?
orac
Re: key dont work
Post by orac »
hi all im back , i have been looking all over to find pics of the BSI fuses. The car i have is a 206 1.4i auto rolland garros.
orac
Re: key dont work
Post by orac »
hi all im back , i have been looking all over to find pics of the BSI fuses. The car i have is a 206 1.4i auto rolland garros. the fusebox as you look at has the OBD socket at the right-hand side,at the bottom, (the edge of the BSI) i can see some more fuses?. it took me many hours to find out what there were. They are marked A,B,C,D,E,F. i have found pics of this showing right to left ,all fuses/amps. the fuse i am trying to find is fuse E, central-locking/lock unlock. fuse B, is windscreen wipers. When i look at what i have there is one fuse missing?,ahh,ahh, im starting to smile now, my wipers work?. So a closer look revealed that my BSI is marked the other way round, left to right!.The fuse thats missing is E, (30A), central-locking, at last headway.I place a fuse in the slot and the doors are nw all trying to lock,seem to be bouncing with a odd noise from rear left door lock?. the doors dont seem to want t stay locked? im now on the right track,i hope, i feel i have got closer to the problem, as the preveious owner must had taken out the fuse, or it blew, would have been easy to find. i will now look at whats going on with the locks ,any ideas would help
Re: key dont work
At a guess, the BSI is getting a door unlock signal which should not be there. It could come from either of the front door locks, the door lock switch next to the hazard warning switch (if fitted) or the remote locking RF receiver and associated electronics in the unit under the steering wheel (Comms 2000).
If you are lucky, the fault might be indicated by Planet, if you can get it onto the car. If not a process of elimination is necessary. You could try disconnecting each of the the locks/switches in turn; perhaps that would isolate the cause and tell you which unit to replace. The fault may even be in the BSI, but leave that till last.
Just thoughts off the top of my head.
EDIT: another idea ( a bit way-out) - maybe the key fob unlock microswitch is stuck on - you could try removing its battery. (You will probably have to re-sync it after replacing the battery, but that's easy)
