Oil low pressure & coolant low level lights
acer54
Post by acer54 »
I've just bought a 2002 Peugeot 206 CC 1.6 litre I wonder if somebody in the know can answer a couple of questions for me, so here go's
1. On turning the ignition on the oil low pressure light does not illuminate.
2. On turning the ignition on the coolant low level light does not illuminate.
Is this normal? I have read in other forums that the oil pressure only lights when their is actually a low oil pressure situation, does the same apply to the low coolant light?
If this is the case is their a procedure to function check all the led lights on the dashboard so that I know that they are working?
Re: Oil low pressure & coolant low level lights
I guess you could check them with Peugeot Planet.
