Currently my roof does not work, I have checked the micro switches and noticed the sliding shelf one does not click like the others. Is it worth replacing ?
Thanks for any advice !
Micro Switch Replace ?
c206c
Re: Micro Switch Replace ?
No point in doing anything until you have replaced faulty parts. It should then work; if it doesn't, then get it scanned for other issues
c206c
Ok will replace and give it a go. Thanks
leegsi
If you can see the switch I have had success in spraying it with contact cleaner and operating it loads of times.
They get full of crap and stick.
c206c
Thanks! Will give that a go tonight before I buy anything then
nikkireid
hi....my roof is totally unresponsive, i did have to force the drivers side lock last time i closed it, could i have damaged something?..what is this micro switch?...
