roof won't open (solved)
MinDe
Post by MinDe »
Got problem with roof. I put cover from tailgate and open latches from inside and then lift roof switcher. Windows open, but then only thing I hear is noice of motor or something like that from back. What can be problem? Already changed relays, previous owner told that they are the problem.
Re: roof won't open,
Check the hydraulic fluid level. http://www.peugeot206cc.co.uk/repair-206/, then EQUIPMENT/SUNROOF/HOOD MECHANISM.
MinDe
Post by MinDe »
there is too much fluid, how i can take it away? I opened screw, but i got only littlebit fluid away. Is there something else way to get it off than just open and wait? There was 2cm over from mark that fluid, now 1cm.
Is there tool, that i could use?
adam.darwin
Post by adam.darwin »
I'm having the same issue. If just watched a video on how to take the roof down and it says when u pull up the side windows will open. This doesn't Ben we get a long beep. The roof has been put back up manually as we couldn't close it
MinDe
Post by MinDe »
roof is working now, I was at my parents last week and my dad told that they might not have but all things like they we're before manual opening. So we checked all things there must be changed before roof can be opened manually. And we found the problem. There was no pressure. So we just put that screw back to place and roof opened! :dance:
