Hi im a consultant tech for citroen i have a roof issue on my wifes car but want to do my homework before i do full post,is there a wiring diagram for 2002 206 cc roof my chassis is VF32DNFUF42265292 as think i have microswitch issues
MANY THANKS DOM
peugeot plannet code was perminant fault boot position
luggage space open switch boot locked switch right and left roof open witch short circuit to poitive
roof beeping above 5mph
PEUGEOT22
Slo
Re: roof beeping above 5mph
Do a search for my relay trick its easy to find.
PEUGEOT22
hi have done a bit of work this possible fault left and right arches have no voltage going to them with roof up and all the rest have a holding voltage pressent relay have looked at some pictures on here will it be ovious what part to press
Slo
Yes you pop the cover off it and press the end of the shiny steel bit.
PEUGEOT22
Cool will give that a go hope it works thought id found it with the voltages issues,least i can still use the roof it just does not finish cycle and beep will let you know,learnt alot so far lol
PEUGEOT22
Sorry but removed cover all I can see is the shiny end of the motor shaft whitch is solid and the internal motor armature and windings can any more light be sheed
Slo
Check the wiring connections as well near the n/s boot lid hinge. It's covered by plastic trunking.
Ours had been pulled out as this wiring also feeds the upper brake light. It thought the boot was open apparently.
PEUGEOT22
Thanks wants to try this relay trick first, but will then manually go through wiring did have a breif look at that part of the loom will post update
PEUGEOT22
REAL shame tryed relay trick but my motor is working all the way back and forward anyway and buy pressing the paddle in the relay is just bypassing switches worth a go though,have noticed my heated rear window is inop buy 3rd brake light is working thanks though slo
PEUGEOT22
dont know if makes a difference i only tryed the closing relay as near on inpossible to safley press opening relay unless u put a midget in the boot lol
PEUGEOT22
did you loose the voltages to the boot latches micro switches,gazza82 wrote:Check the wiring connections as well near the n/s boot lid hinge. It's covered by plastic trunking.
PEUGEOT22
Might be on to a winner but need verification I tested all micro switches again they have a resistance of about 0.2 pressed and nothing open but there is one in the boot lid im getting voltage to but risistance is over 6.00 as a mechanic using this process it would say this is faulty can any one clarify many thanks Dom
PEUGEOT22
Resistance checks back boot lid
Slo
There are 2 switches in the boot latch, when you did the relay trick did you allow it to grab the bootlid at the front catches?
