roof problem
jlabon
roof problem
Post by jlabon »
Hi can anyone HELP ME?? ok I had the interior valeted today and the valeter started to put roof up then stopped operation to clean rear window, as he was cleaning it the roof decided to go back into the boot on its own but the boot lid diddnt close down all the way, tried to put roof back up nothing happens also the car wont start now either seems like immobiliser has activated somehow any ideas please Thanks in advance :thumbs:
Re: roof problem
Firstly NEVER stop the roof mid operation.
Try the relay trick as posted by Slo on here to close the roof, after that try putting it up manually
Re: roof problem
Best way to clean the inside of the rear window is with the roof down in the boot. Open the boot lid and you can get at it. Take care not to damage the heating elements by being too rough.
willwedder
Re: roof problem
Post by willwedder »
Hi there,
The roof wouldn't open so tried manual open, which worked but will not now latch back in to place.
Need to get back to this point to try and fix main issue.Car is 206 cc 2005I have tried every instruction posted on the forum and still cant get the latches on the boot lid back in place.If you have any further ideas I would be grateful. Will
Re: roof problem
I don't know if this will work, but it must be worth a try.
Close the roof (manually if necessary), return the hydraulic controls to normal, perform a BSI reboot (http://www.petercoopercarrepairs.co.uk/ ... cedure.htm) and then try again to open the roof.
