Windows wipers
Mandybill
Windows wipers
Post by Mandybill »
My window wipers stuck in up right position used them this morning stopped for petrol won't start again.went back hour later gave it ago started then stopped again any help please .
Re: Windows wipers
It could be a control problem, but it could be a bad spot on the motor commutator. The motor needs to be tested (e.g. by an auto electrician).
If it has got a bad spot, it is probably cheaper to replace the motor than to attempt a repair. You could try a car breaker, if you have one locally (so that it's easy to return it if it isn't good).
