As above but it's full and the brake icon and stop signs are also on dash. Could it be the sensor/switch by the handbrake? Or any other ideas.
Brake fluid level low but it's full
Nickyandalan206cc
206cc wife's car
Renault Megane RS hubbys car
Nickyandalan206cc
Re: Brake fluid level low but it's full
See page 28 of your owners handbook. If it isn't the brake fluid then it can also indicate that the handbrake is on or hasn't been released correctly - so yes, it could well be the sensor/switch by the handbrake.
It can also indicate a fault with the Electronic Brake Force Distribution system if lit simultaneously with the ABS warning light.
Or the brake fluid level sensor.
