Hii... check engine light dashbord on ??? Help
Issac55555
Hello ... i replace some fuses in the fusebox and the check angine light deshboard and seddenly the light is on .. how can i reset or solve this??? There is no noise ... just lighte on... tnxx
Re: Hii... check engine light dashbord on ??? Help
Try a BSI reboot. Try at least 3 times before you give up - it does not always work the first time.
If that does not help, diagnose with Peugeot Planet 2000.
Issac55555
Tnxx i will check this :-)
