Hi , i need to ask fraind abaut tow thing
1)can i feet some other car rear spoiler to my cc ? Somone do somthin like this ?
2) somone remove the tow handel on the rear boot .. i wont to do this and block the hole .. what the ways ..that i can do this for cosmetic look
Tnxxxx
Hi , rear spoiler for peugote 206 cc .... qst..
Issac55555
Re: Hi , rear spoiler for peugote 206 cc .... qst..
1) I've never seen a spoiler for a CC .. although there are two here http://www.body-kit.co.uk/section.php/1 ... t-spoilers
And one here http://www.ecosse-peugeot.co.uk/show_pr ... 21&appid=3
2) do you mean the steel loop on the rear? It's welded to the bodyshell ... as it the front one .. if you need to be pulled out of a ditch backwards there is nothing else you can use .. there is nothing strong enough and low enough to pull on.
Isn't that loop a legal requirement?
Quite likely but it might depend where to are!! I get the impression Isaac55555 isn't UK based so it might not be quite so restrictive .. personally, I wouldn't remove it
Issac55555
