Hi all im hoping someone can help me :/ my roof on my 206 was working fine until today. When i release the side clips and press the button nothing happens just can hear the micro switch. The only thing i have done is go in the boot? Would be very grateful of some advice as there was no pre warning it was working perfectly.
Thanks in advance
Please help roof fault
Re: Please help roof fault
Check that the blind in the boot is correctly positioned, and the switches are functioning.
markharriers
Thanks for you reply the blind is clipped in but i operate the switch and nothing no warning beep nothing. I retracted the blind and i got a warning beep as i would expect??
We had to replace the operating switch once .. they don't last forever
Pull it out of the centre console gently and check that it is still plugged in first.
markharriers
Thanks guys if i de atract the curtain in the boot and try main switch i get and error beep as i would expect so this tells me the switch is fine??
Yes. How about the switches at the tops of the windscreen pillars?
markharriers
Thanks for your help guys
I have attached and de attached the top left lever and all of a sudden i got a beep and now it works. So now im wondering do i take the pannel off by the lever hook and have a look whats behind there? A micro switch?
There's a microswitch each side. Sometimes they need cleaning. A spray can of electrical switch cleaning fluid is ideal, e.g. this.
markharriers
Thankyou so i best remove the trim and have a lookIanL wrote:There's a microswitch each side. Sometimes they need cleaning. A spray can of electrical switch cleaning fluid is ideal, e.g. this.
