206cc gearbox replacement
Mohanad
Hi I would like to buy a 2006 206 cc 1.6 patrol but it has a bad gearbox how much a good used or new one cost, and dose a 206 gear box fit in the 206 cc ?
Artermis
Re: 206cc gearbox replacement
You'd have to check part numbers to be entirely certain but I would be very surprised if a 'normal' 206 was not the same. The cars share a vast amount of common parts across all the 206 range.
eBay is probably a very easy source of parts, otherwise get telephoning around the breakers yards close to you and see what they have.
I could go round the local breakers yards near me and start throwing rocks blind fold and I'd find it very difficult to not hit a 206, they're everywhere, so it shouldn't be a difficult part to source.
Of course factor in a clutch replacement whilst you're changing the gearbox, for the cost of the parts vs labour you'd be crazy not to change it.
Ben. 2006 1.6 HDi Allure
The MA5 gearbox is fitted to several Peugeot and Citroen models. Get one with the same 6 digit number as yours. There are several option regarding cable or hydraulic clutch, speedo drive and ratios. You really wouldn't want a diesel van gearbox in it!!
Other option would be to get yours repaired.
