Front seat broken, does the 206HB seat fit
starcar
Post by starcar »
Greetings to all
206CC 1.6 S 2002
Passenger seat back stuck reclined, seat slides ok, tilts forwards and slides but can't adjust seat back.
Seems quite a common issue looking back over posts.
Having removed the seat, it looks like that part of the adjustment is sealed inside the pivot mechanism!
Tried the forcing, jiggling method, nothing has worked.
So now looking to find a replacement, does anyone know if the seat from a 206 Hatchback fits or can be made to fit by changing runners etc? these are a much more common item to source than ex 206CC
Thanks. Andrew
Re: Front seat broken, does the 206HB seat fit
Yes can fit, but be sure to get a 3 door one with the same SRS layout and plugs or else you will have probs with airbag light.
starcar
Post by starcar »
Hi Col
Thanks for that. Yes standard 206 3 door hatchback seat, picked up for £30 from my local breaker, stripped, old cover swapped, old runner mechanism bolted on, all fitted fine.
Breaker wanted to sell me a CC seat at a much higher price, didn't know (or admit) that they are based on the same frame!
A bit of info for others with seat problems:-
My passenger seat did not have any airbag sensors/wiring so no issues there, but check for this.
On the 206CC there are two extra seat back supports to the sides, see photo, these are held by captive bolts and nuts, 206HB seat had the fitting holes so easy to swap these parts, guess these give a bit more bucket seat type support.
The 206CC seat base also has two small wire loop towards the rear, these are welded on and were not on the 206HB seat, cover fitted fine though.
Covers are a bit of a fiddle to remove, you need to unbend or cut the many wire loops, I used tie-wraps when re-fitting to make life a bit easier. Take photos and/or notes where they fit.
Wonder if those extra loops are for baby/child car seats?
