307cc roof problam same as 206cc
Redarrow307cc
Post by Redarrow307cc »
Hi there i have been struggling to get any info on the 307cc roof.
My 2007 , 1.6 , 307cc car has got a big roof
Problam .
Story.
Went shopping ,put to much in the back bot ,and
The roof stop working .
Found out how to get to the pump ,and then
Turned pump hole ,and done the emergence
Manual roof operation.
I got the roof to go up with help from dad ,
And began to test everything i could think of.
I ordered a new pump and even a back motor , it all been fitted and still no joy.
The dash keep bleeping and the roof pump will only make a noise when the roof is
Unlocked and open.
Me and dad have tried everything posable .
Is there anybody in the London area that can help me solve this problem .
When we now manual lower the roof ,the back shelf
Will not ,go up to sit the roof in the bot ?
Has anybody got any idea please .
I no my car a 307cc ,but i notice it the same as the 206cc
In respect of roof problams and design.
Can anybody please help me ,i am in Camden london area.
Advance thank you ....
John ....
Free
Re: 307cc roof problam same as 206cc
Post by Free »
I would start by checking the microswitches in the boot if you havent already. Do you know where they are?
Free
2001 206cc 2.0L RFN EW10J4
Redarrow307cc
No i dont no where they are .
And yes very good idea.
I also like to no about this loop wite
Wire they twist and can help....
I need to also look for the back parcel lid
Lock , must be some where ....
Thanks for helping
Free
Post by Free »
There are several microswitches in the boot, they are fragile. Two switches in this picture marked with red dots.
boot
hat rack
Closeup
Free
Post by Free »
Curtainswitch
Boot lid
Boot lid closeup
Boot lock
Free
Post by Free »
White clip in normal position shown here
For manual roof operation pull clip slightly out and tvist to manual position
Redarrow307cc
To see the wite hoops to turn
Where are they ,
Is it possable just open bot and see them
And have access to them ?
Anyone?
Also there a member that done somethink to the
Resestor to lock all the back need that post please
Please help
There's not much on the 307cc on Youtube, but there is on the 206cc, and the white hoops are shown clearly
here at 2.43, but they are coloured red in the video.
Redarrow307cc
There no wite loops on a 307cc
Where it not above showing that not them at all that the front locks
Redarrow307cc
IanL wrote:There's not much on the 307cc on Youtube, but there is on the 206cc, and the white hoops are shown clearly
That the front locks nothink to do
With my question .
The wite loops are not at the front i no that
There at the back both sides somewhere ?
Trying to find out if they exist on a 307cc
Redarrow307cc
Free was you loop picture above from
A 307cc please .....
This site is devoted to the 206cc, so you can't expect much expertise on the 307cc here.
I suggest you try Peugeot Forums.
ianthelaugh
Post by ianthelaugh »
Attached is a wiring diagram found on Peugeot logic web site
Using a multimeter you can check for voltage (ignition on, voltage going to pump, valve unit, etc) continuity of the roof, boot, boot curtain, switches
The diagram shown (shows switches in the roof shut position)
