Hi all,
According to this page, it recommends using a crossbeam when jacking up the car when placing onto axel stands.
http://www.peugeot206cc.co.uk/repair-20 ... ak0vk3.htm
I've tried searching and I can't seem to find one to buy anywhere. Guess I need to improve my googling skills. Any help greatly appreciated.
Crossbeam for jacking?
Re: Crossbeam for jacking?
Look at MachineMart
SAnt
Can't seem to find anything. Perhaps just a galvanised steel U channel (as attachment) would do?
I think a 1m length should be adequate enough, but my concern is the thickness. If it's too thin won't it buckle and create damage?
Aaarrrgg, why isn't there more rear jacking positions so that axle stands can be put on the sill jacking points? Or have I missed something obvious?
2002 206cc 2.0 Manual
How about a length of wooden beam (say 75mm x 75mm), slotted to take the downwards-pointing "fin"?
Shouldn't cost too much.
Sorry, thought you meant something like this ..
Not cheap but might work, more useful and possibly safer than wood?
http://www.justoffbase.co.uk/Cross-Beam ... 0wodtI8B9A
That concentrates the load at the two pads, whereas a slotted beam spreads the load along the whole length. Wood is plenty strong provided there's enough of it, and it will not harm the paint/underseal where it is in contact. And it's cheap - a decent timber merchant could do a couple for less than a fiver, and could slot it with a router, for a bit extra.
Also, the idea is that the load should be borne on the steel either side of the "fin", not on the edge of the fin.
I'd still be reluctant to use the sill at all .... but then I maybe have had too many rusty cars in my time!
Slo
Wood gets my vote every time as the cars sill edge will bite into it rendering it impossible (almost) to move about and slip out from under it. The bottom edge of the sill on the cc is pretty hefty if you are worried about using this to jack the car up because it looks flaky its probably about time you got a different car or a new sill
