Roof problem, motor make sound, noting happens. ecu or motor
RR-Auto
Post by RR-Auto »
Hello, guys. such a great company here, we should go out for a CC gathering :-D .
I just bought a 206 cc , but unfortunately, the roof does not function , such a fun pleasure.
I searched alot about this system and troubleshoot a lot of things. Now i really stuck between the problem of ecu or pump or even something else, you know that, Peugeot:big-grin: ).
when i open the latch and pushing roof button up, it continuously beeping and windows do not operate and also noting will happen.
but if i first turn the windows down, and then open the latch ( also there is no long beep after opening latch ), but the pump starts working, but nothings happen no movement at all.
pump workes in both down or up buttons , both pumps works and nothing moves. I tried to help the pump with manually pulling the boot lid, but I believe the is just about no pressure at all. no movies, even in the lockes. So I started to diagnose the pump. fluid is ok. I test solenoid, sounds like work to me.
I opened 4 pipes which run to first actuators, in the actuator when you keep pushing down on the button just a few drops of oil will come. I test the 4 first pipes with the air, seems ok.
my last guesses are ecu ( because of not correct functioning of windows, and i dont know but it could be probably wrong time signaling to pump selenoid. Or the pump because of lack in pressure .
Regard
yashar
Re: Roof problem, motor make sound, noting happens. ecu or m
When you open the roof catches with the ignition on, do you hear a "bong" sound?
If not, see my reply in this thread.
Have you checked the pressure relief valve is nipped up?
RR-Auto
Post by RR-Auto »
/Yes , I checked the reliefre pressure valve which is located on the pump. i tried both in close and open.
in close n , after a few close and opening manually the roof, it will make a little pressure ( i mean when I open and close the boot lid ( from roof side) it hold a 5 cm distance to full close which I can push it and close.
RR-Auto
Post by RR-Auto »
[quote="IanL"]When you open the roof catches with the ignition on, do you hear a "bong" sound?
Actually with open ignition, after opening the latch I hear no bong sound. I never hered it in any position.
.if I lowered the window before opening the levers no warning tone. and pump work.
and with pump working noting happens.
But wouldn't you think if I had problem with the microswitches, the pump wont response and work at all?
I think you have a pump related problem, and I expect the windows issue is to do with the timings of the operation. It will probably be sorted when the roof starts working
RR-Auto
Post by RR-Auto »
Capncol wrote:I think you have a pump related problem, and I expect the windows issue is to do with the timings of the operation. It will probably be sorted when the roof starts working
Thank you so much for quick reply.
I tried to test pump by taking the pipes out from pump side. when I pull up opening bottun , I haves ome pressure . but as much as I can hold it with my finger. and I believe thats not enough. SO whould you suggest to changing pump?
I suggest you contact http://www.frenchdiagnosticservices.com ... cabriolets. They are the experts.
Yes sounds like faulty pump
Couhullainn
Post by Couhullainn »
First thing to go in a 206cc in order:
Roof
Back Axle
Bearings
Electrics
The earlier the model the more potential for issue with the roof; it does seem like a pump problem though to be fair. I had a squeaking noise in mine so to eliminate the need for a full repair try some 3in1 lubricant wet spray on all clasps and joints and if it still dosn't work then its definately the pump.
