Please help me, This is driving me crazy best I can describe is my radiator fan is lazy, I have read all threads and tried everything..So in summer car overheats to about 100c in traffic and then cuts out rough in idle.Fan only comes on if I turn on the ac or when car is almost in the red whilst accelerating
Temperature has always fluctuated a lot but now car cut out in traffic.
I have changed;
the thermostat
Temperature sender
2 Fan Relays and resistor
Map
Air temp sensor
No corrosion on relays or wires
I have followed the wires, No broken wires and checked conductivity and fuses
When I manually trip the relays both hi/low speeds work.
I am about to wire in an external thermoswitch i can't see any other way around it...
Does anyone know what else I could try???
