Dashboard lights remain on after key is removed
Kate123
Hello, I’m really hoping someone could offer some advice or share a similar experience with me. It’s long winded so please bare with me. Tonight I arrived home and removed the key from the ignition and initially the engine stayed running and all the dashboard lights stayed on. This has never happened before so I was mesmerised by it. Anyway I tried to move the car forward and it cut out but only the dashboard lights stayed illuminated along with milage and clocks etc. The only way I can get them to switch off is to remove the battery. Funny thing is when I hold the break in everything goes off, just like it should do. When I remove my foot they come back on again after a short period. I called the AA out and it literally had the guy stumped. He was looking for signs of moisture but he said it was bone dry. Please can someone share some tips or experiences so I have something to go on when I take it to the garage????? I have a 2006 Peugeot 206cc 1.6 petrol. Thank you
Re: Dashboard lights remain on after key is removed
Hi Kate. Firstly be very careful when disconnecting battery as you could make things worse.
Follow the procedure here http://www.peugeot206cc.co.uk/viewtopic ... 23&t=13473
Also in that guide is a BSI reset method. It may be worth giving that a go first.
