steve747
Posts: 48 Joined: Sat Apr 23, 2016 7:59 pm
Post
by steve747 » Mon Feb 19, 2018 7:36 pm
I have tried google-ing the inlet manifold vaccum connection to the brake servo, the plastic pipe fitting has broken off. I cant find out where to find the description of it so i can buy off Ebay..etc.
I have tried looking on the repair manual on this site, a lot of pages states not found...
Steve
Posts: 1563 Joined: Wed May 13, 2015 10:34 pm
Post
by IanL » Mon Feb 19, 2018 7:42 pm
It would help if you said which engine you have.
For the 1.6 16V petrol, there are two possibilities, depending on:
Date of manufacture
ABS or not
so you also need to quote your RPO number (on the door pillar label).
IanL on Mon Feb 19, 2018 7:47 pm, edited 1 time in total.
steve747
Post
by steve747 » Mon Feb 19, 2018 7:44 pm
I have the 206cc 1.6 16v petrol..
Post
by IanL » Mon Feb 19, 2018 7:53 pm
ok, now quote the RPO number and say whether you have ABS.
steve747
Post
by steve747 » Mon Feb 19, 2018 8:19 pm
I have a 1.6 petrol 2002 , i will post the number tomorrow ..
Many thanks
Steve
Posts: 2129 Joined: Sat Apr 23, 2011 8:41 pm
Post
by gazza82 » Mon Feb 19, 2018 8:37 pm
IanL wrote: ok, now quote the RPO number and say whether you have ABS.
Pretty sure all 206cc's have abs
Post
by IanL » Mon Feb 19, 2018 9:18 pm
If it's 2002 you need 4572 N7.
It's called Brake Vacuum Hose.
steve747
Post
by steve747 » Tue Feb 20, 2018 1:22 pm
The vacuum hose is fine, is the fitting that joins the inlet manifold
Thanks for getting back to me ..
steve
Post
by IanL » Tue Feb 20, 2018 2:45 pm
The hose has a fitting on each end. There is no separate spare part for a corresponding fitting on the inlet manifold. You would have to source a complete inlet manifold, or persuade a breaker to detach it from a manifold (assuming it is removable). The complete part is 0342 H1.
