caravan towing
Martinrushden
caravan towing
Post by Martinrushden »
does anybody use their 206cc for towing a caravan, ive got a 300tdi discovery i use, but on the odd occasion we would like to use the car, max weight of caravan is 1150kg.
206cc 2.0i allure 53plate.
Re: caravan towing
You might be unlucky .. CC is 1100kg max ..
http://www.towingcapacity.co.uk/car-make-model/peugeot/
I'd hate to try as that rear suspension is soft with the torsion bars already. That weight will have the rear end scraping on the road.
Re: caravan towing
The handbook does allow towing, subject to a Peugeot towbar being fitted.
Petrol engines 1100 kg, diesel 900kg for braked trailer. Unbraked only 600 kg for both.
Re: caravan towing
I wouldn't want to tow a caravan with a 206CC even within the limits (and I do a lot of towing)
Martinrushden
Re: caravan towing
Ok thanks for the input,will have to get the other half to change her car .
Re: caravan towing
I'd lose the caravan ... ;-)
Spitfire6
Re: caravan towing
Post by Spitfire6 »
IanL wrote:The handbook does allow towing, subject to a Peugeot towbar being fitted.
I would have thought the diesel would have more power at lower engine revs. I guess they chose a transmission more in favour of lower revs?
Cheers,
Iain.
G6SBH.
Re: caravan towing
I think it may be that the diesel engine weighs more, so reducing the trailer weight to maintain the same GVW.
Re: caravan towing
Correct Ian. My last Mercedes Vito had a bigger payload / towing weight than the current one. Earlier was 2.2 4 cyl / current is 3.0 V6
steve747
Re: caravan towing
Post by steve747 »
I was thinking of towing a trailer tent, the weight is around 500 to 600kgs.
not sure if its going to be braked..
What do you think ???
Steve :thumbs:
Re: caravan towing
Depends on the weight distribution, You don't want too much downforce on the tow ball, especially as the boot is likely to be loaded.
Re: caravan towing
I think you may be over the max un- braked weight. Check on the link above (as well as reading other comments)
At least a trailer tent hasn't got as much windage as a caravan.
