Peugeot 206 not starting and roof
JAYJAY123
Post by JAYJAY123 »
Hi All
I am having issues with my car
Its not starting up
its not turning over
The battery seems fine
also the roof makes a non stop bleeping sound which the roof is closed fully, it only bleeps when going over 5mph
:cry: :cry: :cry: :cry:
Please help
Re: Peugeot 206 not starting and roof
Get the starter motor tested.
It is possible that one of the roof switches is not working correctly, so the roof ECU thinks the roof is not closed.
JAYJAY123
Post by JAYJAY123 »
Thank you
I will get these looked at this eve
I agree with starter (or cabling to it)
JAYJAY123
Post by JAYJAY123 »
I apologise
ive never used the forum before
Peugeot 206 cc 1.6 manual petrol
ive only had the car a week
the problem has turned out to be the crank sensor, i have cleaned it up a bit which is starting up at least but need to actually change it
The roof I'm still having issues with as its non stop bleeping, the roof is fully up and locked but everytime i go over 5mph it bleeps
Crank sensor wouldn't stop it from cranking. It would prevent it from starting however.
I'm not sure about this, but I have an idea that it could be due to one of the microswitches on the top of the windscreen pillars signalling open instead of locked. Sometimes it's just a bit of dirt, and people have had success just spraying into it with contact cleaning spray (do NOT use WD40 - it is a dirt magnet).
