Hello, I'm new in the forum and I recently bought a 2002 1.6 CC, I'm from Central America so the spares here for this car are really scarce.
I had some problem with the rear windows and I tried to check what the problem was, the cables of the elevating mechanism were tangled, so I proceded to disconnect the motor of the rear driver window. When I finnished and connected the motor, I leave the mechanism without the cables, If I push the window switch, I can only hear the rear motor spinning but not pass to elevate the front window.
My mechanic checked the front window motor and looks like it's damaged so I need a replacement, I was wondering if I can use the motor of a 206 RC or if other model have a similar motor that can work.
Thanks and best regards.
Driver Window Motor Replacement
Re: Driver Window Motor Replacement
The doors are different on the CC compared to other 206 models. You would think the motors would be the same though, but knowing French cars, probably not.
Can you take the faulty motor off and go to a breakers yard and compare? A lot of Citroens share components with Peugeot, so worth looking at those too
New cables available here:
https://www.ebay.co.uk/itm/PEUGEOT-206C ... 2749.l2649
You can't tell from the Peugeot parts list whether the motors are the same, as they are supplied new complete with the lifting gear, which is different. You would have to compare them. And even if they look the same, the gearing could be different.
There are plenty of used ones for the 206cc on ebay.co.uk.
batcommander
Dear Capncol and IanL, thanks for your answers, I have already bought the repair kits for the rear windows in Amazon but thanks for the advice.
Regarding the front window motor, taking on count your advices, I will try to buy a used motor from a CC, I think that the time and money I will expend looking for an equivalent would be the same or more than buying directly the right one. Thanks and best regards.
