The steering on my 2006 206 with 52,000 miles on the clock suddenly became 'stiff'.
I checked the tyres...they were ok. So the problem appears to be the power steering. There are several 'bits' that may need replacing...What is the 'likely' problem and will I need a bank loan.
Thanks.
Is it a power steering problem ?
Re: Is it a power steering problem ?
Have you checked the level of the power steering fluid? Has it gone down? May need topping up - if so find the leak.
cantgrumble
Thanks for that......Yes I have checked the fluid level,though it's not quite clear where the level 'line' is.
The fluid is about an inch below the cap and I can see no obvious leaks from pipes leading to and from.
The dipstick on the cap has two marks, min and max. The level should at least above min, and should not exceed max.
The power steering pump is belt driven. Is the belt slipping or broken?
cantgrumble
Hell......could'nt see a dipstick on cap....will check again.
Thanks.
Thanks.
cantgrumble
Dooooh.........Need to go to Specsavers ! dipstick is there. Fluid level ok and belt seems ok.
