Hello guys i have been having this problem with my roof for ages now and i decided to invest in PP2000 i finally got it now i get this error code which i have no idea where to start.... any help on which switch it actually is or if its a cable that is damaged?
thanks in advance!
Edit: i just notice something can some one confirm this?
on the left side of the boot there is a switch working fine but on the right side it seems as if i am missing a switch. But i cannot see a unplugged cable or where the switch should go to if there was one there.
Roof fault codes
arthasin
Roof fault codes
Re: Roof fault codes
Have you seen this post, http://www.peugeot206cc.co.uk/viewtopic.php?f=5&t=12945?
You will see that quite a number of the switches are not repeated on the other side. Switches I and K are the ones mentioned in your screenshot, and they are not repeated on the other side.
According to some posts I've seen, you can see the state of the switches with PP2000, and you can work them and observe the results.
arthasin
Oh i see i taught i was looking at J and E with E missing. and as for reading switch state with pp2000 could you point me in the direction of this thread? because i did a few searches couldn't find anything about pp2000IanL wrote:Have you seen this post, /viewtopic.php?f=5&t=12945?
and switch state.
arthasin
HA thank you! i ran a live test with PP2000 and i found the actual switch that is acting up. Turn out it's not the switch but the cable running to the switch that is flickering between positive and negative. i attached a multimeter to it and it's dancing between voltage and no voltage constant. i'v been told that means bad earth(ground). But now i have no clue what to do next any help?IanL wrote:/forums/206-35/206-cc-roof-problems-320329/
If you state which switch, I can consult the wiring database. Please identify the switch by reference to the switch sketch in the link given in my post of 28 April.
