Where to buy Power Steering hoses?
jramsden1
Post by jramsden1 »
Another question... sorry!
Having trouble finding anywhere that will sell the PAS hoses (specifically the high pressure hose, but nowhere seems to be selling any of them! At least that I can see anyway).
Car is: Peugeot 206cc 1.6 16v 2005 Allure.
Thanks as always!
Re: Where to buy Power Steering hoses?
Dealer? Otherwise contact a hydralic hose specialist who might be able to refurb yours.
jramsden1
Post by jramsden1 »
Thanks! May be able to get around having to find them. Leaking power steering fluid (Yellow?! I'm sure it should be red...) but think I've traced it back to the pressure sensor, I reckon it's the little gasket that's had it. Any idea if this is a common leak point?
jramsden1
Post by jramsden1 »
Thought I'd do a test and put some spamspam roll on the sensor and bracket where I found most fluid and not exactly sure what my results mean.
The blue pressure sensor seems to be the primary cause, overnight leaving this (the blotch in the middle):
However the black bracket underneath also let out a bit of residue I think:
I guess it could have dripped through, but doesn't seem like it to me. Presumably even any weeping like this is an MOT fail. Are these brackets known for leaking. Is it simply a job of switching them for a new bracket, and if so - any idea where I can get the same kind?
Thanks for any help!
