Hello!
I am having some issues with a "switch" in the trunk (sorry if i use the wrong terms, trying to translate from swedish but to no avail).
When i have had the trunk open or when i get the roof down i get a infernal beeping in the car since it is registering that the boot is not closed correctly.
I only have to press the right end of the boot with one finger then it closes completely, but doing this every time i put down or up the roof or even use the boot will drive me mad.
Any ideas to easily rectify the issue?
Thanks in advance!
Trunk/ Boot not registering being closed
DankDeathPunch
Re: Trunk/ Boot not registering being closed
See http://www.peugeot206cc.co.uk/viewtopic.php?f=5&t=12945.
Sounds like the problem is the Boot Closed Switch (F). (Boot = Trunk)
DankDeathPunch
Thank you! Now i know what too look for!
It is probably (E) upper boot cover locked switch since one have to press down in that general area to get rid of the beeping.
Thanks again!
Thanks again!
