1.6 16v timing tools
Ben jp4
Hello, my engine has developed the dreaded tappet noise. They realy don't like life above 4000rpm. Im thinking about having a go at it myself, because im cheap,, more precisely skint and i don't want to pay £50 for tools i will proberbly only use once. I know you can use two 8mm drill bits for the cams, any ideas what i can substitute for a flywheel locking tool?
Re: 1.6 16v timing tools
It will stay on TDC, just mark it with tippex to instantly see if you've moved it
Ben jp4
Thanks for that. Im relatively inexperianced at engine work so i was thinking its best to go belt and braces but i supose its all part of the learning experiance to put it back together and find your a tooth out. The cambelt was done last year so hopefully they left some marks.
