Thought I'd do a test and put some spamspam roll on the power steering fluid sensor and bracket where I found most fluid and not exactly sure what my results mean.
The blue pressure sensor seems to be the primary cause, overnight leaving this (the blotch in the middle):
However the black bracket underneath also let out a bit of residue I think:
I guess it could have dripped through, but doesn't seem like it to me. Presumably even any weeping like this is an MOT fail. Are these brackets known for leaking. Is it simply a job of switching them for a new bracket, and if so - any idea where I can get the same kind?
Thanks for any help!
Power Steering Leak
jramsden1
Power Steering Leak
Re: Power Steering Leak
The black plastic supports? They simply hold the pipes apart .. it's going to be behind that and the actual pipe I would guess.
They are likely to be fairly PSA specific so a dealer might be the first stop
- Fihen
Whilst changing ancillary drive belt on my 206cc (tu5jp4 engine) I noticed red fluid on parts of engine beneath the power steering pump. Anyone know where I should start to find the culprit??? I could live in hope and discover just a seal. The steering pump was empty. I just seem to find more and more things that are putting of my first drive.
Clean the area thoroughly so no fluid leeching from elsewhere.
Puff some talc around the area. Your leak will stain the talc (which can be washed off when finished with)
- Fihen
Thanks for that. I have taken the pump out and found the leak is from the reservoir. I have repaied it with rapid fix glue. Its been a week since the repair and to date no leak.
