Roof stuck down
Dawn1985
Roof stuck down
My Peugeot 206cc roof is down and won’t go back up. When I hit the roof button the windows go down and you can hear the motor trying to put the roof up but nothing happens then it starts to beep. Tried to manually put it back up but the cord is missing to manual drop the parcel shelf. Can anyonehelp?
Re: Roof stuck down
Most 206ccs do not have the pull cord - it was dropped from the design. The instruction what to do instead are in the handbook for the car. If you don't have it, go to http://public.servicebox.peugeot.com/APddb/ and choose English (top right) before clicking through to your car and age bracket.
As for what is wrong, you could try checking the hydraulic fluid level, see http://www.peugeot206cc.co.uk/repair-20 ... id0bf3.htm. If it's not that, it could be the pressure release has worked open (see the handbook) or the contacts on the electrically-operated valve on the pump unit (see this video http://www.peugeot206cc.co.uk/viewtopic.php?f=5&t=12920.
