Cable replacement NSF Window?
jayjd
Post by jayjd »
Hi guys (is that even politically correct these days) :hmm:
Just got my hands on a 206cc, I have taken of the passenger door trim to find that the window mechanism cable is frayed and tangled, preventing closing and opening of the window. I want to replace this, if possible.
My question is, is this doable and if so, how easy is it to replace?
Cheers
Re: Cable replacement NSF Window?
According to the Service Box, you have to lower the window 2/3 of travel, remove the door card and plastic seal and prise the window glass out of the mechanism. Then suspend it in the raised position with (very) adhesive tape.
Then you can either drill out the rivets holding the regulator in place (maybe replace with screws when refitting?) and remove it to replace the wires, or you can try doing it in situ, but I'm not sure how easy that would be.
You probably need to disconnect the loudspeaker and remove it complete with support bracket.
New wires are available on eBay, e.g. here.
Good luck, and let us know how it goes.
jayjd
Post by jayjd »
Hey IanL thank you very much for your quick response, I did post back before but it seems to have disappeared.
Ive ordered the kit so await delivery and my attempts at installing it lol. :) Ill be sure to report back on how it goes.
