roof jammed open
weeszaty13
roof jammed open
Post by weeszaty13 »
hi,my roof stopped working whilst it was almost fully open,now cant get it closed due to top shelf not retracting. also cant get in boot due to the roof jamming :hmm:
Re: roof jammed open
Have you tried putting up manually?
Capncol wrote:Have you tried putting up manually?
He needs to get to the pump to depressurise, but he can't access the boot :(
Second thoughts: Is that true? If the roof is not fully closed, the boot lid will be tilted up, and you should be able to get in and operate the pressure release.
The procedure is given in the Owners Manual, and there are demos on YouTube.
weeszaty13
hi there thanks for replies :thumbs: i managed to get the roof up so far manually and release the hydrologic bit to keep boot open further,but the pull cord to release top shelf is missing ,any ideas as the roof wont pass this it gets jammed on window..
tia kirsty
The pull cord was dropped from the design early in the production run. Later versions of the owners manual tell you what to do instead.
If you don't have the manual, go to http://public.servicebox.peugeot.com/APddb/, choose language car, model and date bracket.
Have you looked through the Roof section of the Problems forum? You may find some useful help there.
The missing cord has been covered several times too
